What’s the fault codes related to esp ,bas and pre safe not active
mercmancdi
Templepatrick
mercedes E320 cdi sport ,vw Tiguan R line , M B cls , bmw convertible
where’s bas switch? Please feel free to decode.
Anyone connect any of these in simple terms to my 3 messages that come and go. Eps , bas , safety warning not active.
Clearing faults but would expect the esp and bas to come back.
Where is bas switch. ?
Code C1201. Bas release switch intermittent.plausibilty
C1034. Fault in can com with control unit eis. Intermittent
I imagine that the brake assist switch would be in the abs pump housing?
BAS is designed to add additional breaking force if the system detects emergency braking but its algorithms determine that additional braking force could be safely applied.
Has any work been carried out on the car before the faults showed up?
Not that I know of , front pads look not long fitted.
I'd be sending that car back to the trader to sort out if I were you.
Lol. No panic ,I bought the car from a trader I know in a straight sale cheap ,knowing I had to do bits and pieces as a hobby.
With the help on here I hope to get few we problems sorted by myself.
