What command system? ?????
Bigbargainjay
W203 c220 cdi
Not sure where to start as I have been reading alot about the command units but doesn't really solve my problem.
I have a 2011 w204 c250 cdi, facelift model. I don't have the online command option neither the sd card slot in the front. I do have the usb slot in the armrest tho. How do I find out what system this is or can someone shed abit of light on it. I also have the becker satnav in the glove box.
Cheers in advance
Its an Audio-20. If it has a CD changer built in, its an Audio-20-CD-Changer
Cheers
Richard
ps, it is not a 'COMAND' system. A 'COMAND" system is the high end navigation system (as oppose to the Audio-20 or the Audio-50)
Cheers for the reply mate, so how do I upgrade to comand then ? Is it a case of getting a new stereo? Or more to it than that ?
Still a bit confused, is it a case of just getting the new wiring kit or do I need more , it says that only possible for 2012 onwards as pre 2012 has different loom, mine is 2011 but the new style dash. would like to know how much to upgrade and exactly what I need.
Cheers
You have NTG 4.5 audio-20 with Becker map pilot. The car is a model year 2012.
To fit comand you will need;
Comand NTG 4.5 unit
New bigger screen
Retrofit Kit
Labour to remove old parts and install new.
Coding
Map pin
Wherever you get the comand from you will need the 20 character activation pin code for it. Once installed and coded you will then need a map pin code to load the maps onto it. whatever maps are on it will be disabled as soon as you plug the unit in.
Cheers for that, any idea how much it would be all in ?
