Dunhamkid
Flash said:It’s known as the heater Booster System – it enables the vehicle to be heated up as quickly as possible. The Heater Booster system automatically activates if the outside temperature is below 8 degrees Celsius and Coolant Temperature below 70 degrees . It switches off again at higher temperatures.
To activate the Heater booster system from the Menu follow the below:
Settings Menu > select “Heater”
This will bring up “Heater Booster” Menu
Select one of following:
- AUTOMATIC
- Off With AC Off
- OFF
Flash
Which menu are you talking about and how do you select it?
