hi guys clk 200 w208 2001
can you help, just got some new alloys 18in,, back fit fine, but i need spacers for the front ,do any one know what size i need 10mm 15mm or 20 mm, if you can advise please do
thanks
offset 35
Offset: 35Rim Width: 8.5JStud Diameter: 112Rim Diameter: 18Number of Studs: 5Rim Structure: One PieceManufacturer Part Number: 116
reason is the front wheel bearing is pokeing out through the caps hole ??
8.5 on the front is pretty wide to be honest , is it not touching on your suspension ? If you space them out , will they not stand proud of the arches ( and hence fail the MOT ) ?
