Vehicle manufacturers will always quote the bottom range of pressures suitable for any tyre. This is to ensure the most 'comfortable' drive conditions for the average consumer.
However tyre manufactures will typically quote a wider range of pressures, as a slightly higher pressure will result in a better handling car.
Experiment with pressures ...say up to 6-8 psi above your placarded pressures. Find the pressure that suits your driving the best. This is a compromise between handling and comfort ....your choice.
Also ...if you want to get a bit more technical ...track the wear pattern on the tyres ..say at 3000 mile (5000 km) intervals. Edge wear could mean pressure are tooo low ...centre wear could mean pressures are too high. Caveat: Removing any other factors, like suspension set up, wheel alignment and such.
Easy Guide: Follow your placard in the filler cap, maybe add 1-3 PSI , and your good.
note: always measure cold, Even a short distance will increase heat in a tyre.
