So basically the audio on the COMMAND is better than the Audio20, but since the factory speakers are poor it wont make much difference?Audio20 is the entry level unit. It's is referred to as Audio20 NTG4.5 (the NTG bit signifies the product line, and is used by MB for both Audio20 and COMAND).
COMAND has built-in navigation, with the maps residing on an internal 100gb HDD. Audio20 does not have navigation, but you can add it by fitting the optional Becker Map Pilot unit in the glovebox. However, the Becker Map Pilot navigation software isn't as good as that of COMAND.
Audio20 has smaller low-res display, while COMAND has a larger high-res display.
Audio20 has very basic sound, COMAND has a much better amplifier (though to hear the difference you'll need to upgrade the original speakers to something better, the factory speakers are very poor).
You can tell whether it's Audio20 or COMAND in several ways:
- COMAND has an SD-Card slot, Audio20 doesn't.
- COMAND has a larger screen, Audio20 has a smaller screen (and a larger black bezel).
- When switching on the car, COMAND will say "Don't let COMAND distract you...", Audio20 will say "Don't let the SYSTEM distract you..."
- Run the VIN in an online VIN decoder, and check the codes in the 5xx region.
Also does any code with 5xx from the VIN means COMMAND?
For example the screenshot.
Also could the Audio20 be upgraded to Gen2, like the COMMAND can?
I'm currently using phone on my old car with AUX and just want to know if it's worth it to have more options from the NTG or should just install Carplay at some point.
Also does bluetooth work on the Audio20?
Sorry for asking so many questions
