Almost certainly should go to the inlet manifold beyond the throttle plate where the vacuum is highest. It looks as if it leads to the one way filter/valve mounted on the inner wing from which a clear vacuum line runs down to the EZL ignition unit mounted on the wing. The EZL needs a vacuum signal to modify the ignition advance curve. You need to look for a blank spigot or a disconnected rubber connector possibly on the underside.
