Tekman
I DO APPOLOGIES TO ALL OLD SUBJECT
I have a w204 C320 CDI Elegance , so got a eml on checked it out using Icarsoft Mb V3 pics , problem with hot film sensor found out that When I was driving in yorkshire moors tractors were moving hay and such my air intake sucket it up part block, eml and sensor so new filters in cleaned air flow system plug in no fix. requested it to reset NO
told it to relearn NOPE Grandson inlaw brought his bosch scanner 10 secs done no issue
I what a scanner that will look at values of air mass and see which is under peforming under or over paraminters I what one that will reset and relearn
I have watched Killhertz videos espesily Icastoft cr max system will that machine do that on mine if so great will get one but I would like to know before I buy one
so any recomendations
1- scan system read fault codes
2- delete said code
3- be able to watch the values to see if sensors are working
4 - HELP
Dear WEB GOD`s can we have a section on scanners and multi meters only where recomendations are put which vehicle used or which it want, I will be putting in new sensors from Germany all I want to do is put them in plug scanner in and relearn system reset airfilter Job done easy without spending days on we looking at vids reading stories in hope of someone saying yep you what this device.
and I know about Exentry way to expencieve £500 or less
thank you anyone
seeing that cars now days you need a scanner I know this going to happen again when I change airfilters
2- delete said code
4 - HELP
thank you anyone
