White smoke.
sW124
HI everybody.
i have a w124.I noticed a white smoke coming from the engine.what can have caused that?
thanks.
could be condensation evaporating on a cold morning, or cracked cylinder head. Or many different scenarios.
Please provide more info and we can offer more accurate advice.
Engine size?
Smoke from where exactly? Engine, exhaust, radiator?
Just at start or continually?
Hello I had a petrol 330ci and it seemed to do this a lot, noticed especially in traffic (stop start) as my car seemed almost the only one in the line doing it...
Apparently its 'normal' or so I was told, cold mornings / evenings it seems worse...
Never did anything about it and can ran fine.
My car produces white smoke in the mornings, I thought it might be condensation in the exhaust system being burnt off?
infact i did not start the car for about 2 weeks coz i was absent.IT is a 230E w124.
the smoke comes from somewhere in the engine compartment ,more exactly under the hood.
To be clear. You are talking about smoke from under the bonnet, not from the exhaust? Oh !!
yes that is it.When i opened my hood,i noticed some smoke coming from the engine.
Could it be evaporation or something like that.REmember i did not start up the car for 2 weeks.
Everytime I was focussed on what you are trying to show you moved the camera. Try a much longer steadier shot. If its coming from the region of the exhaust manifold it could be just steam being generated due to moisture on the manifold.
yes i confirm that it comes from the exhaust manifold.
Do u confirm that i should not worry?what causes the smoke?
It certainly sounds like moisture being "burnt " off the hot exhaust manifold. Is it still happening, or was it just the first time after the car was sitting.
Have you got a slight oil leak from the head that is dripping down onto the exhaust and being burned off when you first start the car?
