Another Mercedss problem that is common across the last 6 years, whitewood within the diamond cut 18" AMG alloys.
Normally appears around the centre badge. Covered under warranty jf picked up soon enough.
I very much suspect that this is caused by careless tyre fitters who try and prise-off the caps using a screwdriver (slightly damaging the alloy wheel and allowing moisture and corrosion to set under the paint) instead of gently pushing it out from the inside with a screw driver butt once the wheel is off the car.
Mercamd it is looking like a strip and repaint for you . Weather, and the damp, get in to the alloy, and then the white worm or spider is born But an easy fix .
