Wierd.. Fuel indicator having a rave!
BillyW124
North West London
W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
ahh, good to be back on here after some time off!
Ok so comming back from me honeymoon i was itching to get back in the 124 for a spin after 3 weeks of non use.
Started up a dream no issues no funky clunky sounds just a nice one time crank, the usual little high idle then all calm.
Drove for a good 30 mins around town when i noticed the fuel gauge decided i must have left her too long and wanted to take the P*ss. While driving the gauge bounces left and right down to the empty and then bounces back up again..
whats going on here, never had it happen before? :(
what bit needs replacing then?:bannana:
must add, noticed it was more frequent this evening whilst driving home. bouncing gauge!
yea thats what i think must be sticky! The sender or whatever makes the reading might be jammed/clogged?
I think the sender is easy enough to get at in your Coupe. Just pull back the trim on the rear wall of your boot. It hooks over little upstands and you will see a massive hex headed nut. Your sender is attached to this I think. You can replace this or do as I do in my Estate, give the dash on top of the fuel gauge needle a thump. That seems to bring it into line for a while.
I think this is a gauge fault, not a sensor. I've seen it on quite a few cars now. On one, with an erratic oil pressure gauge, according to the history the sensor had been replaced at least twice
Unless you want to replace or repair the binnacle I'd ignore it
Nick Froome
the independent Mercedes Estate specialists
Thanks, ill give the dash a little smack if it happens again! it feels as though it may be one of those itermittant things. It was fine this morning.
if you taught it was the sender then you can get a additive to add to the petrol tank and it would clean that with a full tank of petrol
the only other time i had this was due to a bad earth
but maybe she is just giving out that your married now and shes not happy >>>>
Exactly!
...about the sender in the tank then, does anybody know if these need replacing after a certain period of time?
im sure mines hasn't been changed in 16yrs!
they can give trouble i have changed a few in w202's of the same age not a big job once you know how
a bit more reading needed and i bet some one here has more info on the w124
Fuel sender replaced = no bouncey raving gauge. :thumb:
good stuff! i replaced the sender, nothing happened, i then changed the cluster and ba bamm, works! 30 minute job.
