Window Wind Noise Help
jpskiller
Preston, Up North!
Wifes
Few weeks back I had to change the motor in drivers side window, since then there is an annoying wind noise from around 30mph+ I've tried in vain for last few weeks to adjust window every way possibly to reduce this with little success.:mad:
So I have decided to give up on that and was woundering if anyone knows if Wind Deflectors would cure it:confused:
Setting up windows is a delicate art, you need a piece of thin cardboard of the cereal packet type.
Just slip this in all round the glass, if one side is too tight then this will lift the glass away on the other end, so you must back the tight side off a little.
With luck you may see the original marks where it was from new, put it back there and start again
The car is a four door, not a Coupe.
Wind deflectors will make things worse as they spoil the airflow, just try resetting the glass evenly all round.
ah well its only on the drivers side so doesnt affect me:D :devil:
Persevere, if it's only happened since your repair it must be something you have changed...
