lambymb
Hi, just wondered if anyone has encountered a similar issue. My W209 CLK has an issue where if I press the indicator stalk to activate the washers nothing appears to happen. Wipers do not move nor any spray. The wipers work fine other than this.
I did initially think it was a dodgy pump but as the wipers do not activate really cannot be the case. The only other couple of things it could be is either a faulty stalk or relay/fuse.
Anyone had a similar issue?
