Kilmarnockbunne
Hi. I have a problem with a w211 220cdi 2007. Out of the blue I've had a problem with warning lights and starting when hot.
The problems are abs lights come on along with most of the engine warning lights, Speedo stops working, car sticks in park or drive if trying reverse. If you turn off the engine it won't crank for 5 to 10mins.
I have plugged a Carly in and it shows a problem with the 30g circuit saying it is under voltage. Is looks like it's a relay issue which isn't closing over to allow the car to reset which in turns throwing up.the fault codes. However I cannot find anything for a fix online and I have no idea where the 30g relay would be - loads of references to it but no locations.
Please can anyone help?
