Seamster15
Can anyone tell me the difference between Xenon and Bi-Xenon headlamps?
Simon
Simon
Flash said:In order to physically tell if MB has xenons or bi xeonons:
Xenons have frosted glass (on eralier models) up and till 2003:
Bi Xenons: Clean clear hadlamps (one can physically tell the difference between bi xenons and the standard clear halogen headlamps used to update the old frosted halogen headlamps i.e. W203 face lift as the glass is not totally crystal clear as the bi xenon headlamps)
Bi xenons use just "one" single highly chaged xenon bulb and a projector is used. Bi xenons are supposed to have better vision than xenons (may just be margnbal though) as xenons are pretty good anyway.
GRAV888 said:Correct me if I'm wrong anybody, but :
Xenon's are only on dipped beam with an ordinary bulb for main beam.
Bi-xenon's use a mirror inside the light unit to allow the light to be reflected as a main beam too.
Click Here
Brian WH said:My Bi-Xenons
Rory said:So that must render the inside, main beam only, headlight useful only for flashing at other cars?
Do the Bi-Xenons light up if you flash someone for an extended period?
fuzzer said:The Bi xenon has a mirror as said above , so when you flash someone , the regular h7 bulb comes on plus the mirror in the xenon moves out the way. Its like floodlights.
For the people that make the mistake of flashing me thinking ive got my main beam on , it must be terribly blinding for them to discover the truth
Tan said:R129 series SL's with Xenons dont have frosted glass over the Xenon bulb.
That's what I would have expected. However, is it just that Xenons are a little slow to react - ie if you hold the flash on for a few seconds do they switch to main beam - or are they inoperative in 'flash' mode?DieselE said:The W211 may be different to either Fuzzer's BMW or C270. I experimented against the garage door this morning (sad I know but it was only with the lights I assure you!). Flashing brings on the halogen main beam units only. If the xenons are on they stay on dip beam. When high beam is selected, the halogen units come on and the xenons switch to high beam.
Rory said:That's what I would have expected. However, is it just that Xenons are a little slow to react - ie if you hold the flash on for a few seconds do they switch to main beam - or are they inoperative in 'flash' mode?
This is because Xenon capsules take about 2 minutes to get up to temperature, so flashing doesn't really work unless they've been on for a bit.DieselE said:When the xenons are on dip, flashing the lights brings on the halogen units and puts the xenons on high beam. If the lights are off then flashing is with the halogens only.
