I have seen a few people mention they have fitted an xpipe and i was wondering if they do one for the c320 cdi (w204). And what other mods would you advice? Thank you
1971 280SL, 1988 300CE TT, 1994 E320 CAB, 1999 AMG C43, 2005 AMG G55K 2008 CLK63 AMG BLACK SERIES
If your Diesel is turbocharged an X-pipe is of no value for power gain.
Same applies to petrol turbo engines.
It may however change the tone of the exhaust note.
The purpose of an "X" or "H" pipe is to create a much better scavenging effect from the cylinders which results in a power gain.
The effect is only seen on normally aspirated engines with true dual exhausts.
"True dual exhaust" defined as two down pipes from the engine never converging into a "Y".
The two pipes can meet in a two in-two out silencer as the exhaust gas is not truly commingled.
The turbo compressor wheel is in between the cylinder exhaust outlet and the down pipe.
The compressor wheel spins from the exhaust gas and precludes any pulse/wave from a prior firing cylinder to scavenge the next firing cylinder.
