1st and 2nd Gear sticking in 2001 Golf MK4 1.4 Petrol
Hello evenyone, I have recently bought a 2001 Golf MK4 1.4 petrol for my partner to learn driving. It shifts to all gears smoothly when car is switched off. Goes into 1st gear as well at the start (with small effort). But have to really use force to bring it to 2nd gear and back to 1st is a nightmare.
3rd, 4th and 5th gear are not too bad (or rather OK), reverse is OK too ( strange but nothing like 2nd)
Took the car to few mechanics but no one seemed to be able to confirm what the issue is, some say clutch some gear box, some synchomesh, bushings, linkage ....cat dog, camel etc!
Has anyone experienced similar sort of issue? I have very little knowledge on cars, just been reading and googling around but very mixed views everywhere.
Can anyone point me in the right direction please?
Regards
A
I would suspect the clutch is not fully disengaging , the first place I’d look is ( assuming it is a hydraulically actuated clutch ) is at the fluid reservoir to see if it is full . If the level is low , that could point to a leak in the clutch hydraulics .
Some of the VW cars we have had in the past had cable operated clutches , and if the Mk4 has a cable , it may be out of adjustment.
After that you could be looking at the clutch release bearing , but this will involve removing the gearbox , at which point you would be as well renewing the clutch disc , cover plate and release bearing . If there is a slave cylinder , and if it is inside the bell housing , you would be as well to change that too since the cost of these components is not high , while the time and trouble in removing the gearbox is a greater consideration .
I remember replacing the clutch in one of the Mk2 Polos we had , and it was enough to disconnect the driveshafts , remove the starter motor ( after disconnecting the battery ) , undo the gearbox mounting bolts and slide the gearbox to one side .it was a long time ago , but I recall then having enough clearance to do the job without needing to completely remove the gearbox . The clutch cable then had to be adjusted so that the clutch would fully disengage , and that it was fully ‘in’ with the pedal released , hence the release bearing fully released .
I also did the same job on my Audi 100GL and on a Passat GLS , essentially the same job .
We had later Golfs in the family ( everything from Mk1s to Mk6 ) but I can’t recall when , if at all , they moved from cable operation to hydraulic operation . I never did as much work on the later ones .
Too late for the OP methinks; they checked out of the forum the same day that they checked in.
