chrisk2010
heavy cutting with wool pads can cause marring or pig tails, esp on softer paint but if the paint doesn't respond to a heavy cut foam pad then wool is always the best bet, you will also find that they don't heat up that much so helps with panel temps, no matter how good you are with a compounding set, you will always need to finish down with at least a 2nd stage anyway so it removed any marring from the cutting.
Appreciate the advice it pretty much confirms what i thought.
When i get around to it i was going to do a test section with a green hex logic and some scholl concept, if no good move to and orange if still no good green and a heavier cut compound.
I'm trying to go at it gently because i'm so rusty lol.
