D
Deleted member 37751
Guest
I’ve just spoken to German Car Specialists on your behalf and they’ve quoted circa £600 for the job.I called Star Commercials, they quoted me £1800 to replace the oil cooler seals![]()
No worries pal, how much did the job end up costing you in the end?Sorry pal (SPX) only just seen your post above
That sounds pretty good considering the work time involved .£775 & 2 round trips to Nuneaton
From what I gather, any mechanics that work on Mercedes regularly will have a lot of experience of fixing this fault!Yes I agree, and with the knowledge that the mechanic doing the job had done dozens of the same job
Mercland in Nuneaton is 1.5 hours away . Jay will have done loads of cooler seals
Could well be the oil cooler seals , which is from below the oil cooler in the middle of the engines V , not visible easily , but runs down the back of the engine .
yes you definitely need an MB specialist (they will all have done it before ) .
I hope the monkeys that have nipped up the sump bolts haven’t caused more unnecessary problems .
Im sure someone will recommend a specialist soon
