SleekLemur
Thanks, Grober. This looks perfect. I need to learn about the various suppliers.
O-ring will be a standard size off-the-shelf easily available item - just get the dimensions (diameter will be easier measured from the component it attaches to). Don't let that put you off opening up your existing pump.Trouble is, I'm not sure if you can buy the o-ring seal for the impeller cover.
Doesn't really imply fuel starvation.Mixture very rich. Black plugs and soot on driveway. leaned mixture. No sooty exhaust, but still stalls.
Won't the pump stop when the engine ceases turning? (safety feature). Then re-prime when ignition switched back on?Then I decided to deliberated drive it until it completely stalls and listen for the fuel pump (yes, I know. Why didn't I do that in the first place? Sorry...) and no whine from the pump. switch ignition off and wait a minute and fuel pump whines and car drives.
Is the mixture weakening during warm up as it should or maintaining cold-start mixture?I'm still a little concerned that the engine seems fine at tickover and will rev in neutral after I'm forced to pull over to the side of the road. As soon as I try to pull away though, it fluffs, but will be ok on tickover..... That's was was directing me towards the coil or condenser being the issue.
It's about 3 inches diameter, but yes, I will have a go at rebuilding the original, especially as there's a rebuilt item currently for sale for €3,250.O-ring will be a standard size off-the-shelf easily available item - just get the dimensions (diameter will be easier measured from the component it attaches to). Don't let that put you off opening up your existing pump.
No, pump is continuous, as there is a return to the tank.Doesn't really imply fuel starvation.
Am not throwing anything away, although I always change the distributor for electronic on any classic car I own.Sounds like you're getting ready to throw parts without diagnosing the problem. How about getting a fuel pressure gauge or checking the CO. You could be running super rich which would also give you the same symptoms.
The cold start system uses wax and is notorious for getting stuck open.
An exact OD or ID and the cross-sectional diameter (thickness) identifies it by dimensions. Only material unknown. Research typical for petrol. If in doubt buy different types (eg nitrile, viton) and compare pliability with original. Viton works with petrol.It's about 3 inches diameter, but yes, I will have a go at rebuilding the original, especially as there's a rebuilt item currently for sale for €3,250.
Struggling to believe that Mercedes sold a car that in the event of a collision that stopped the engine turning but with the ignition still on would continue to pump fuel to the engine bay (into possible ruptured pipes/components). To get clarity on this I suggest tracing the switching wire for the fuel pump relay back to source and establish that it is a straightforward 'hot when ign on' connection. It coming from anything that is in communication with engine turning/not turning, oil pressure, or fuel pressure suggests the required safety pump-disable is in place.No, pump is continuous, as there is a return to the tank.
My post is of absolutely zero help unfortunately, but "Hugo" is a really lovely looking car.Hi All and thanks so much for all the great replies. Much appreciated! Well, one thing I noticed this morning was that it is missing the main engine-to-body earth strap. Goodness knows how it was even running. But that wasn't the problem. Tried switching coil-to-distributor HT lead. Nope. All pipes for venting are brand new and I tried running the car with one of those emergency petrol caps, which was a loose fit. Still conked out. Mixture very rich. Black plugs and soot on driveway. leaned mixture. No sooty exhaust, but still stalls. Fuel tank was professionally cleaned and the whole system checked right through to spray pattern from the injectors (when the car was rebuilt in 2019, prior to two years in the museum). Then I decided to deliberated drive it until it completely stalls and listen for the fuel pump (yes, I know. Why didn't I do that in the first place? Sorry...) and no whine from the pump. switch ignition off and wait a minute and fuel pump whines and car drives.
So.....assuming it is the electric fuel feed pump and this does seem a distinct possibility after two years of inactivity, what are my options ? Haven't checked for a replacement yet, but does anyone have any recommendations?
Thanks again and here's a link to some pics of "Hugo".
3 new items by Tim Cherrett
photos.app.goo.gl
My 6,3 used the same mfi system and fuel pump. 100% sure that the pump is not continuiusly running with ignition live.
Thanks Shaun, your message of support is greatly appreciated!My post is of absolutely zero help unfortunately, but "Hugo" is a really lovely looking car.
Sadly I guess it will inevitably come with a few 60 year old problems.
I genuinely hope you get them all resolved, because I will stay subscribed to this thread for more updates
Fingers crossedNew coil arrives tomorrow, but am not too hopeful that is the issue.....that was about 4 diagnoses ago!
