I have a 1990 260e which has covered 129000 miles. From a cold start there is a clatter from the top end of the engine for 2/3 seconds during which time it also misfires. In about 1 in 10 cold starts a light tapping noise can be heard for 15/20 seconds. Once running it sounds fine. If I turn the key on and off so the engine turns for a second the problem does not occur. I use 15/40 oil which is changed regularly. Any help would be much appreciated.
