300ce offset?? amg wheels??
ADY1983
Yeovil, Somerset
300CE-24 Sportline, MK1 Golf GTI Campaign Edition, Scirocco GTII
300ce offset?? amg wheels?? Help pleasse!
Hi i recently bought 2 genuine 18" amg wheels part no. 2204013602 with an offset of 44. got them cheap as he only had 2 :D , My plan was to buy 2 more from ebay or wherever. I have seen a 17" wheel on ebay could i use these on the front??? item no. is 4608237688 the offset is 37. Are any of these wheels any good or am i wasting my time and cash any help please. :confused:
cheers Ady.
No chance of making them fit.
You bought 2 S Class wheels. Mixing 17 &18 inch wheels??? Please tell me that was a typo!
No not a typo :o , thats why i asked i cant have a bigger wheel on the back then? and what offset do i need for the 300ce? cheers
ET35 or thereabouts ... (within one or two )
Odd sizes seems to work for the crossfire though!
As Nav has said, S class wheels won't fit, not with that offset anyway. It would not be a good idea to mix different diameter wheels really as well. You are best looking for a set of AMG 17" wheels designed to fit these cars, with an offset as Howard has mentioned of nearer 35ish rather than 44?
Try and buy a set of four that are correct and match, it'll save you a lot of headaches :)
Will
Ok cheers for the help, i will look for some more, my 17" OZs will do for now ;)
the offset depends on the width of the rim, the wider the rim the lower the negative offset.
HTH
Andy
