Just wondered if any UK member has done an 82mm throttle body upgrade on their ''55k''.
Many thanks.
I have one fitted and Lopes80, BrabusSL and Acid have them fitted as well. Not sure about anyone else.
what are the benefits?
I bet no one has bothered measuring the pressure drop across the throttle body. I would expect the intake trunking to be generating most of the pressure drop.
That changing the throttle body will do nothing unless the engine can breath more air than the throttle body can pass.
If the restriction is elsewhere, then it's a waste of time. No point using a larger garden hose if there is a kink in it.
For sure, the system is only as good as its narrowest point.
Ricky has too....
I would imagine that the larger TB would be looked at only in conjunction with other mods.
Bearing in mind that these engines are forced induction (supercharged), the tuning potential is quite large.
Add a few PSI to the boost (pulley swap?) and if the TB is restrictive (?) then I guess it makes sense
Did MB make/utilise different sized TBs throughout the 55K range - I know the power outputs varied over the years/models.
What does the SLR do for the extra power?
As much info as poss please.....you will not bore me with tiny detail....let the typing commence.....or if you wish I would be happy to give you a phone call. Ta.
