Im pretty sure most mercedes since the beginning of time start off in 2nd. Only if you floor it will it use 1st.
Could simply be the selector switch - IIRC this is a reasonably common problem.The only thing I can presume is that my 'tests' have been conducted when the 'box still considers itself to be cold. Or. as Renault suggests, mine is not working properly.
It comes into its own in motorway crawling jams, where creeping in C seems to be the right speed to keep up with the traffic,
Reading more about this... it seems that when in C it will only start in 2nd if you start-off gently, but if you do so with a heavy foot then it will start in 1st anyway.
Just to throw a slight spanner in the works, does the gear selection of first or second also depend on whether the engine is diesle or petrol? I also see that the first gear ratio in some 5g boxes are slightly different either 3.59:1 or 3.95:1 see 5G-Tronic - Wikipedia, the free encyclopedia
No, the only criteria are those listed in the attachment to post #6
Interestingly, that link also confirms that these boxes are adaptive to driving style...which the US guys always believed but some on this forum would deny.
Are you referring to the 5G or 7G? I didn't think anyone here doubted both these boxes adapt (continuously) to one's driving style? What was hotly debated was the possibility of resetting these adaptions without using STAR . Which they can't.
I see. I think the US guys merely reset them to the default position.
Which is all one can do, even with STAR. It wipes the memory of how the driver has been driving and returns it to factory default.
Don't confuse 'adaption' with 'update' they are two separate things.
Was I?
My manual states that in W (or C for later cars) the car will start off in 2nd (except if 1st is selected). I can confirm that no matter how heavy footed I am in W, the car starts off in 2nd.
No myth here.
Corned, maybe yours is not working as it should. Try this test. Stop your car on a hill, release your foot from the brake. Now note what happens when in C or S. If I do this, the car creeps forward in S, but stops and stays put in W. In fact I can control the car by flicking the switch between the two.
