- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, ML63, CLK350 'Vert, Triumph Sprint (Bike not Dolly...),
Still plugging (no pun intended) on with the thing - still misfiring on no.5 cylinder, which is the one it was misfiring on originally. New distributor caps & rotors, new HT leads, new plugs, have made no difference. Some will recall that when I changed the plugs, the one in no.5 showed no signs of combustion having taken place recently.
I took a look at the throttle body wiring loom's internals, and it's OK; a bit rigid and crispy, but not in need of immediate replacement, so I'm looking to get the car running properly before I replace it.
It now looks 95% certain that it's the injector. I've done over 50 miles since fitting the new plugs, but the brand-new plug in no. 5 is as shiny as when I fitted it. Just in case, I refitted one of the old (and in pretty good nick) plugs, but the misfire is still there. The injector for that cylinder has the same resistance (c. 14.5 ohms) as two others, so it seems highly likely that either it is blocked, or that the refurbished loom from SiLec, either through being fitted by a thick-fingered numpty (not me...) or just possibly because it is faulty, is not activating that injector. I've cleaned the contacts at the injector; no change.
Sunday looks like a good day to get my hands dirty again. It seems to me that the easy way to find out without special test kit (which I don't have) is to swap the questionable injector to another cylinder, and see if the misfire moves with it. It looks quite straightforward, if time-consuming, to remove the fuel rail and injectors, but I can't tell from visual inspection how the injectors are held into the fuel rail. Could some kind soul enlighten me?
I've also read somewhere that some injectors are fitted with an internal filter; does anyone know whether that's the case on a 1994 SL500?
The car is going in to WGMB on Monday morning anyway, so if I can't identify and (with luck) rectify the cause of the misfire that will still have to be done, and I'll get the codes read and the gearbox oil and filter changed anyway, though the gearbox is greatly improved with being driven.
I'm still getting there...
