A 170 woes
denbo
A 170
have searched high and low for last 5 weeks to try and sort non run dilema out ,
had air bubbles in pipes so changed seals ,,,to no avail,, so changed all the pipes new from merc ,,, still not start and run ,,,so changed high pressure pump ,,still not go ,,it wont start without a good squirt of brake cleaner in the intake and will sit and run all day on tick over but cuts out soon as any loads put on in gear no fault codes registering on magic computer box nephew has ,,so any ideas apart from chucking a match on it :D
So what - you still have air in the pipes?
no got rid of the air ,,is there a pump in tank ? didnt think there was
tried swapping relays still no
good
no a snap on solus pro
