I had one in recently which as two collapsed spring mounts and a 4 inch hole in the battery tray!
The front chassis rails I could put my fist through them. It was a E430 210.
There is no excuse for such a rusty car.
I thought that W210's were made in Germany and that it was the W202's and W203's that came from South Africa....or is it that the steel for all Merc's comes from South Africa?
Just done the underside of mine even more shocking than what you can see
Having been involved in W210 corrosion I can't agree about the steel being the cause.
The corrosion always starts where the paint coat is breached either by being chipped or simply not covering properly in the first place.
I have never seen one where corrosion simply starts inside the metal.
As a lay person with no specialist knowledge this problem does appear more to do with the steel than the paint, but this is an observation inviting debate? The underside of the car corrodes far worse than the top of the vehicle and it reminds me so much of the old Vauxhall\Ford problems way back in the 1950's early 1960's when we saw the first Vauxhall Victor's and the Ford Anglia with the inward sloping rear window. These cars were made from cheap, reconstituted steel which had a the life span of soggy paper.Having been involved in W210 corrosion I can't agree about the steel being the cause.
I do agree though that most if not all these problems are surface rust, as opposed from rust coming from the inside out.
Regards
John
We had the days with the French cars, on a CX you could have perfect doors and a rusty front an back, or a perfect front and back and rusty doors, so that would discount the paint.
I think that the only way we can solve this is if someone gets hold of seemingly good panel and takes the paint off with stripper. sanding does to much damage to the surface to see
Maybe I will just do that. That would make good sense
