A170 Steering whine
brucemillar
Next Door to Alice - 25 'kin years now
C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
Hi
My Outlaws A170 has a really bad squeel from the steering when you make any kind of turn. Worse still the the steering is tight (too tight) it is feeling like it may stick. To me it feels like it is sticking inside the car on the column. It certanly sound like it. Can anybody tell me if there is a bush inside the car behind the steering shroud? If yes is it replaceable?
Many Thanks
Bruce
Check the fluid level. Low levels can cause strange noises.
168 or 169 ?
There are a couple of UJ's on the 168 that are never greased , one is in the engine bay to the right of the engine and is covered with a rubber gaiter. Peel it back and pack the joint with moly grease.
The other one is under the dash , drivers side , do the same.
The fluid level in the pump is critical to get right , from underfilled to over filled is literally a 'splash' of liquid. Make sure the car is level and cool when you measure it.
168 or 169 ?
Howard.
many thanks
The one under the dash. How would I get to it?
Just look up from the pedals , you'll see the UJ.
I'd have to agree with Bobby Dazzler, check the fluid level and condition of the power steering fluid first. If there is a filter in the fluid resovoir, check that as well as it probably won't have ever been changed.
It would also be worth getting someone to turn the steering wheel while you're outside the car and listening where the squel is coming from.
