A210 starting problem
thegolfather
My recently acquired 21o evo has an intermittent starting problem,on occasions the only dash light will be the SRS and it will not start,go back later and after turning the key a short delay then it starts,is this a common fault?
Most likely to be the starter motor.
Is a 4 hour job and a little awkward.
Hi thanks,if it was the starter why are the dash lights not illuminating?the starter is making no noises,thanks.
Oh I see.
Just re-read your post and it makes better sense now. You may have a ignition switch problem instead. A-class ignition switches are normally bullet proof.
