glojo said:
I'm sorry to be so critical, but that type of service is not good enough. Can you recall a purple coloured car at their workshop? How fortunate you checked the oil level. The engine should have been tested once it was put back together and the oil level rechecked.
John
Not only that John, but the engine was run up and the cooling system flushed 3 times to clear out the oil from the cooling system.
I'm a bit puzzled as to why the
low oil warning light didn't come on as the oil isn't up to the top of the red plastic bit on the dip-stick.
Full bill as follows:-
Description..............................................Quantity....................Total
Oil............................................................
6.5 .................... 29.25
Labour.........................................................6.5.................. 331.50
Check for oil contamination in coolant. Remove cyl head
and check for distortion- OK.
Renew cyl head gasket and rebuild. Remove radiator and
flush out. Refit radiator and run engine up flushing cooling
system 3 times.
Replenish antifreeze. Re-wire ignition coils.
MA104 010 21 30 N/STK GASKET KIT.............1 @32.96...................32.96
MA104 015 02 20 N/STK GASKET..................1 @4.15......................4.15
MA110 200 05 15 N/STK THERMOSTAT..........1 @11.81...................11.81
MA017 997 21 48 N/STK SEAL RING...............5 @1.55.....................7.75
MA104 010 37 20 N/STK GASKET KIT.............1 @70.67..................70.67
MA104 203 04 82 N/STK HOSE......................1 @4.81.....................4.81
MA202 540 60 81 PIN BUSHING HOU..............3 @29.66...................88.98
MA104 180 01 09 B010102 FILTER CARTR.......1 @6.71......................6.71
MA000 989 40 20 N/STK SEALING COMPOU.....1 @16.33...................16.33
MA000 989 08 25/11 B010303 ANTI-FREEZE....1 @21.02...................21.02
Net £625.94
VAT £109.54
Total £735.48
