gazza9911
Hi All,
Driving home tonight and the dash info beeped and said a bulb had gone - not long after the ABS - BAS & ESP warning showed up!!!!
I pulled over turned the ignition off and took key out -I put the key back in but it would not turn. After a minute or so the key turned and the car started. About a mile up the road they lit up again.
When I got home I had a quick look - with the engine running (parked), pushing the brake pedal the brake lights lit and also the nearside side light lit up to. When I turned on the head lights (the dash said bulb out) the brake lights light up.
Any ideas / suggestions welcome.
Cheers
GA
Cheers
GA
