After leaving the car at the airport for a few days in the week, the car started fine but the Battery Convenience message came up. The car drove fine for 40 miles then the Battery Convenience warning flashed up again but all still worked fine. Then got to within 5 miles from home and the Radio etc switched off followed by the air con blowers slowing down, with about a couple of miles of my journey left a red warning came up saying battery and alternator fault. Got home, turned it off, gave it a few minutes, tried to fire it up but battery was dead.
Bought a new main battery the following morning, fitted it and everything started working, however the battery convenience warning was still there albeit everything was working. Drove about 40 odd miles since, then today when driving the car, the radio turned off again followed by the aircon fans slowing down. A new red warning sign came up this time of just a picture of a battery with visit workshop. Drove home, switched the car off, gave it a couple of minutes and started it up, started ok albeit a touch sluggish. Suspect the main battery is draining and low on charge.
So what do I do next?
Replace the alternator? (Reason being that the new main battery is already nearly dead)
Replace the auxiliary battery that powers the convenience functions? (Reasoning being that this may already have been failing, but by replacing the main battery it has compensated for the aux battery being dead but is now being drained as a result)
Replace the voltage regulator? (Reason being that the main battery is not retaining charge and have read threads in the past where this is often the issue)
Any advice appreciated.
Jules.
Jules.
