mb240
My battery has given up. It;s the stock 017 type, and is branded MB, and made by Varta.
Should I just get a stock replacement or can anyone recommend a "better" battery. At the moment I am using an emergency-purchased "Hugel" which is 12V 88Ah, the only one available as they have *no* other available MB batteries even in Dublin of this type, so it will need to come from Germany. The stock is 12V 100Ah.
So, can anyone advise me on replacements, in the sense of, either get the stock replacement or is there a new cooler, better, stronger battery I should get. I am having no problems with the Hugel, but at 88Ah, I wouldn't want to risk a couple of non-starts cracking as it would empty out quite quickly.
EDIT: cost is not an issue
