air con control unit......
checked resistance on all wires and all seems ok.......
last night, checked resistance on blue/green wire leading to compressor....was ok.
decided to check the voltage on plug going into compressor.....voltage was zero?!?!?!?!?!?!:confused:
Looked into the plug and the end of the wire was not touching the contact sheath properly............checked the voltage to the wire.....13.4 volts!:confused:
Think i found the problem.................shoved some cable into the plug and pushed it into the compressor, hey presto, working fine:) :) :)
all this time, it was a poor connction in the actual plug for the compressor.............even this morning, it worked fine all the way to work.....
thanks to you all and to glenn for his advise..............owe you a pint mate, next GTG........hopefully, this is sorted now....fingers crossed:) :rock:
whos a happy bunny.................:rock: :rock: :rock:
:bannana: :bannana: :bannana:
at least now i can help others with their a/c problems.............:)
There was an earth cable corroded and attached to nothing in my engine bay! Ian Walker fixed it for me... :)
hey Paul, nice to hear you've solved!
hopefully, that was the problem..........i'm happy that its working at the moment................................if it works for the next 4-5 days, then its resolved...
now its a waiting game?!?!?!??!
thanks to all that had input on this thread...........:bannana:
best of all no mbz bill its £300 to open the bonnet and if they get their hands dirty ???£500 and if you need a new widget which costs a few ££££ but 7 hrs to fit ??
well done
Well done Paul. A good bit of traditional fault finding.
Phew! best to get on with some work now, glad you've located it, can't beat a good problem to solve, the harder it is the more satisfying it is!!!!!!
Sensor
This might be your evaporator sensor, this would cause the problems you describe.
A new one is £30 and it is up under the steering shaft inside the car. You will need 4 pairs of hands though.
