Merc59
Hi all hopefully this is posted in the correct section of the forum.
My air con on the above 2008 c class stopped working (flashing red light when button pressed) garage had it in no refrigerant they did a vacuum test, it passed and recharged the system Nd ac worked for 1 day.
Rebooked in and they did a leak test using nitrogen no leaks were detected at the condenser, compressor or associated pipes nor anything through vents in car when cabin fan running. Only when they removed the plenum in the engine bay and with fan running tested the fan box and cabin filter box a leak was detected. They are assuming that the evaporator is a fault which requires the dash out to replace.
Having enquired with dealership and another garage they are surprised that this has failed.
Can you let me know your thoughts etc. I am suspicious as nothing was seen on the vents and am wondering if the pressure regulating valve is leaking against bulkhead and the fan pulled it in.
