Hi all
My air con doesn't work, never has since I bought the car last October (I could have sworn I checked it.....). Anyway with the sunny weather looking like its here to stay I thought I'd do something about it (there is NO reduction in air temp whatsoever!!!!)
So...
The tank at the front (2) and all associated connections look ok.
There is no wiring diagram in my Haynes for the electricals but I can say that if I disconnect connector (1) (a pressure switch??)the two fans at the front (3rd pic down) kick in for a few seconds when I turn the ignition to stage 2 with the aircon on.
Also, with the aircon on, the compressor doesn't really turn with the belt, I assume that this is because pressure switch? (1) tells the clutch not to engage.....
I used a screwdriver to push in the ball/nipple on the inside of the valve (3) to check for pressure/gas. Not a sausage. Completely empty
Pressed this one in too (4) with the same result (but a dribble of oil).
The connections at the bottom of the condenser looked ok, no real signs of corrosion. Couldn't really see the condenser due to stuff in the way and limited time.
So, now for the questions....
- Is there anything else I should look for before I take it to a garage?
- Should I go to kwikfit (heard some good reviews on this forum) for a top-up or go to a specialist on the grounds that there may be a bigger problem lurking (given that the system is totally flat?)
- Anyone know a good specialist in/near Edinburgh?
Thanks in advance for any replies
Chris
So...
Chris
