kam09
- Jul 1, 2013
- E350cdi coupe sport obs black
I'm thinking it's a leak on my rear air bags or something happening with the struts.. Will be going on the ramp soon..
Mine does have the "vehicle rising" message come up once engine is started.. however I'm using the car day to day..I believe I have the same problem. When the car is parked for a few days without being used, both rear drops low. I have to manually press button to raise the car. There is no warning on the dashboard though. Mine has done 46k miles
So I want to test the Valve Block- spraying with soapy water or disconnecting the compressor supply pipe to see if air is leaking back. However, I've read Arnott recommend swapping air lines on the valve block to see if the issue occurs on the same corner again (e.g. swap RL with FR). If it's same RL corner again then it's the airbag, if it moves to FR, then it's the valve block. Seems like a great diagnosis trick. However one video I watched the mechanic said don't do this if you're not using a scanner (I don't have one). Theory is- say RL goes down, car wants to pump it up but air goes into FR, which will overfill & burst the airbag. Will that really happen? Surely if I leave the car off it won't try to refill & corner will go down without car attempting refilling?2016 C350e: Similar intermittant Airmatic issue- rear left corner drops randomly whilst parked, rear right corner as well, but not so much. It is very intermittant- away on holidays for 10days & return to airport car park- levels are fine. Yesterday park the car in the driveway & a few hours later the rear is down. When I start car get the "Vehicle is rising" message & the car is pumped up again & all is fine. I had a new MB compressor fitted by my indie MB mechanic in Jan '22, so my first instinct/hope is that perhaps the compressor pressure relief valve is faulty? But if this was the case would all 4 corners not be down? At least if this is the issue the MB compressor has a 2yr warranty(?) so hopefully the mechanic would get a free replacement, but would probably still charge for his labour. Maybe a Rear Left Air Bag leak, which is what the indie MB mechanic said over the phone, going on the info that it was that corner only- but then why would it happen intermittantly & not every time I park? Otherwise- valve block leak? Rear distribution block leak? Air line leak?
Is it best just to jack the car up, remove front left & rear left wheels, front left wheel arch liner & try leak testing as much as possible?
Hi,So I want to test the Valve Block- spraying with soapy water or disconnecting the compressor supply pipe to see if air is leaking back. However, I've read Arnott recommend swapping air lines on the valve block to see if the issue occurs on the same corner again (e.g. swap RL with FR). If it's same RL corner again then it's the airbag, if it moves to FR, then it's the valve block. Seems like a great diagnosis trick. However one video I watched the mechanic said don't do this if you're not using a scanner (I don't have one). Theory is- say RL goes down, car wants to pump it up but air goes into FR, which will overfill & burst the airbag. Will that really happen? Surely if I leave the car off it won't try to refill & corner will go down without car attempting refilling?
