I have a gurring, rattleing kind of noise that im pretty sure is coming from the alternator. Its worse from cold start up but once warm only seems to occur at around 1000 rpm. I have noticed a few times that after a good long run the noise disapears altogether but after the car has cooled down, its there again.!!???? Could this be the bearings in the alternator?
I've also noticed when i rev the engine the lights get brighter, which in my experiance means that the alternator aint working as it should.
I spose my question is, could knackered bearings(if thats what the noise is) cause the alternator to not give full voltage on tickover?
Thanks,
Stu
Thanks,
Stu
