I didn't, my comand unit is a 163 comand. I intend to swap it for a 208/210 comand later and install the canbus wiring, cluster and steering wheel.BenzComander said:Which wire did you use for the ilumination circuit?
The illumination wire is blue and can be found hanging around under the panel surrounding the shift lever IIRC.
