Greenthing
Hello, I`m going to attempt to change the glow plugs on my 1998 w202 c250 turbo diesel. I`ve read up as much as I can from this and other forums but there`s a couple of questions I`d like answered if possible please.
On one thread it says I need a special tool `11mm socket IIRC`, but the plugs I`ve bought are 12mm. Is this because I`ve bought a cheaper set of plugs and the ones I`m about to remove are probably 11mm? I`ve done much searching but can`t find the special tool or an 11mm glow plug socket anywhere.
Also, if I remove the inlet manifold, do I need a socket anyway or can I get to them with a spanner. If I do need a socket will an ordinary socket work or does it have to be a deep reach?
The reason I ask this is that I have a limited ammount of time do the job and will have to make sure I have the right tools at hand.
