machasm
Hi All,
Just wanted to say what a great job Olly from Prestige Car Services has done on my C32.
I had noticed that the C32 had developed a bit of an ATF leak and after trawling these forums deduced that it must be the infamous 'O' ring on the electrical connector.
Olly confirmed this and after draining the ATF, removing the sump and filter we then discovered that the screw holding the plug in place had stripped its thread and was spinning round without coming out.
This meant that the bottom part of the AT had to be removed and the plastic electrical plate broken off (what a horrible sound that plastic breaking makes!).
Anyway, after sending his sidekick to MB Portsmouth to retrieve another electrical plate (@£115 ex VAT!) the new one was fitted.
A new sump gasket fitted and a new 'O' ring fitted.
The gearbox was then flushed through (as well as could be) and then topped up with new ATF.
The car was checked over for anything else and test driven.
Valeo radiator checked against MB "problem" database and verified clear.
Olly charged me for 2 hours labour at a very reasonable £50 p.h and I came away feeling that the job was well done.
The whole time I was able to be right beside him as he worked and felt that he never rushed anything nor cut any corners.
Good job Olly.
Keep it up mate.
Adrian.
Good job Olly.
Keep it up mate.
Adrian.
