I recently contacted Longlife exhausts in London as I need to mate up my Remus rear box with the original exhaust and this is the answer I received......they seem to be a lot cheaper than fitting an OEM exhaust and its stainless steel and guaranteed for life.
Anyone used them ?
"We can certainly build a Stainless Steel Centre section for your Mercedes C230K.This is the section between the cat and the backbox. We can also mate this to the Remus backbox.
All our systems are tailor-made using stainless steel (T304) and come with a no hassle, fully transferable LIFETIME GUARANTEE so it is literally fit and forget.
Our free-flow systems are designed for efficiency, which can give increased power and improved MPG. Usually the most noticeable improvement is in low down torque
giving better acceleration.
To design and build a Longlife Stainless centre section from the catalytic converter through to the rear of your vehicle would cost £199 (including fitting and VAT). Trusting the backbox is a direct fit we wiull charge an additional £40 to fit.
Hand-building and fitting your custom made system takes approximately 2-3 hours by appointment at our Wallington, Surrey centre. We can also make a courtesy car available while we build your exhaust system, subject to availability.
When you arrive and before work commences, we will agree and confirm the final details of the system design. After work is completed, every exhaust undergoes a thorough twelve point quality check, to ensure complete reliability and performance."
Anyone used them ?
