Aps 30?
zenman63
Warwickshire
2016 L450 Range Rover 4.4 AB, 2015 GTs 2017 Range rover evoque
Hi, Will an APS 30 just plug and play in place of an APS10?
And then get a hide away bluetooth kit to work with it.
Going in a 2006 Vito.
I installed a APS30 system in my old w163, before I installed Comand, it was plug and play.
I now have the same APS30 installed in my SL, and only issue was adding a speed pulse wire.
Thanks for the reply
Just looking at the 10.1 nav update, does it take post code?
I have an APS30 in my W202.
It is plug and play if you already have the speed pulse wired in. (Pin 1 in block A).
I don't know how you would get bluetooth to work on it thought as these units were made years before bluetooth was even invented.
And as for postcodes, I think it will allow the first part of post code entry for London only i.e. NW12 and then select the street you want.
