APS30 aerial
mr. shr
Can anyone help me source an antenna for the APS30 unit?
What is the connector type called so I can do a search for one?
Thanks.
shr.
Sorry, but STATS007 is wrong!
It is a WICLIC connection for the APS 30.
I have it myself!
Try Ebay Item number: 170141775746
I've had two APS30s and bought both aerials from eBay as listed above.
Yeah, I believe you, it might fit as well, but the FACRA plug is definitely for a VW or AUDI or SCODA navigatin unit, while the WICLIC is for Mercedes, Becker APS30, Sony, JVC, Pioneer navigation units.
I know some are interchangeable - maybe he just listed the wrong name on the auction?
PM Alfie to see if he supplies them.
If he has them then they will certainly be a better quality than e-bay.
You need one with a Fakra connection - usually on eBay for £16 or so.
Looking at the images it seems that the WICLIC connector is what I need. Stats007, the item in your link looks like a WICLIC plug so that should do the job.
Just gotta hunt for the cheapest one out there.
Karlefr, that ebay item number is also spot on but shipping costs are a bit high as it's located in Germany.
Are these antenna pretty much all the same thing or do I need to worry about anything in particular?
Also, my car has a short black stub aerial mounted on the roof just above the rear screen. I believe this is part of the telephone pre wiring but not sure. Is there any chance this could also double as a GPS antenna?
(Will ask in Electronics)
Yep, already tried. Unfortunately he doesn't stock any.
