AT cooling(and warming up ?) via radiator
dogan124
Turkey-Ankara
1991 w124 300td (estate) & 1988 Golf II TD
Hi...
The AT box cooling is via radiator of the engine through some pipes passing in.
So ;
- Does the AT box has a thermostat to give the fluid way to radiator when hot?
-Does the radiator only cools the AT fluid down, or the other way (in cold weather) it may warm the fluid up ?
I'm asking this to understand whether I need it in winter. I want to remove it from radiator for a seperate cooling for AT.
Thanks,
Dogan
It is a cooler and not the other way round,, the are many transmission coolers on the market
