Aug 22, 2008 #1 Satch MB Enthusiast Joined Nov 24, 2003 Messages 3,508 Location Surrey Car S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser This comes up on a pretty regular basis and so hope this is helps a bit. Last edited: Oct 28, 2013
Aug 22, 2008 #2 SilverSaloon MB Enthusiast Joined Mar 16, 2004 Messages 7,758 Car 1994 W124 E300D Estate, 1985 R107 280SL Yep, £10.29 without discount
Aug 22, 2008 #3 OP OP Satch MB Enthusiast Joined Nov 24, 2003 Messages 3,508 Location Surrey Car S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser SilverSaloon said: Yep, £10.29 without discount Click to expand... Opie Oils sell the Fuchs for £9.01 per litre inc VAT less an MBClub discount http://www.opieoils.co.uk/car-clubs.aspx
Aug 23, 2008 #4 B BIGjoe Active Member Joined Jan 13, 2007 Messages 65 Satch said: This comes up on a pretty regular basis and so hope this is helps a bit. Click to expand... Is this new ATF suitable for the older 5 speeds?
Aug 23, 2008 #5 OP OP Satch MB Enthusiast Joined Nov 24, 2003 Messages 3,508 Location Surrey Car S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser BIGjoe said: Is this new ATF suitable for the older 5 speeds? Click to expand... Says it is compatible with 722.3, 722.4 and 722.6 so if you have one of those transmissions the answer is yes. Now I come to think on it, all 722.6 transmissions are 5 speed. 722.3/4 are 4 speeds dating back to the 1990's 722.5 is however a 5 speed and excluded, so I presume not that one. As far as I can tell the 722.5 is found in: 1990-1993 300SL 1994-1995 S320 1994-1997 SL320 So, as ever, RTFM Last edited: Aug 23, 2008
Aug 23, 2008 #6 B BIGjoe Active Member Joined Jan 13, 2007 Messages 65 So it should be ok in a 2003 ML 270?
Aug 23, 2008 #7 OP OP Satch MB Enthusiast Joined Nov 24, 2003 Messages 3,508 Location Surrey Car S211 E320Cdi Avantgarde Estate & Toyota Land Cruiser BIGjoe said: So it should be ok in a 2003 ML 270? Click to expand... As far as I know all the ML's had a 722.6 until the seven speed came in. Answer will be in here somewhere: http://www.whnet.com/4x4/index.html http://www.whnet.com/4x4/shoptalk.html
