Audio 20 - Silly question
kwannie
Sorry for this silly question.
My steering wheel used to be able to select the radio station memory. But now, it only selects the frequency instead. Any idea?
i.e
Before, pressing the up and down arrow will select memory 1, memory 2...etc
Now, pressing up and down arrow changes the frequency...
If you dont have Comand you can change it in the settings menu in the cluster.
I am quite new to this. I have a W203 C220 CDI 2004
I can't find frequency or station in cluster.
What is command by the way?
Page through the menus until you see Settings. scroll through settings until you see Radio select station
Thanks. Still no joy. Under the settings menu I have only the following
Reset to factory
Instrument cluster
Time/date
Lighting
Vehicle
Heater
I have tried resetting to factory setting but still no joy. Any other ideas?
2004 C class sports pack
I tried everything and went through the whole owners menu and no mention of it.
Reset to factory
Instrument cluster
Time/date
Lighting
Vehicle
Heater
Is it not under Instrument Cluster?
Audio 20.
Under Instrument cluster, only have the following
select temp display
select speed and total distance
select language
select display
I'm sure we've had this before but I'm buggered if I can remember how we fixed it!!
No, it's a simple fix I saw/read it only the other day...
Go to Settings
Select Vehicle menu
use up and down arrows to go to audio search function
use + or - to select frequency or memory.
Memory will move up and down between your pre set stations
Frequency will move up and down to next available station
