striker600
- Nov 13, 2007
- Location
- south yorkshire
- 2001 c270 cdi avantgarde estate Auto w203
My Automatic gearbox has a intermittent fault which has happened 3 times so far. This problem first occured on 23/11/09. After a couple of miles drive i parked the car, left engine running for a couple of mins then resumed driving. I then noticed the gearbox was locked in 3rd gear. I tried to shift gears left & right with the gearstick but it wouldnt shift gears, Kickdown & The W & S mode switch wouldnt work either. The only way to get the gearbox working correctly again was to turn engine off, remove ignition key,& restart engine.
This same fault happend yesterday 5/12/09, again when the engine had been ideling a couple of mins, after a 5 mile drive. I then set off & again the car was stuck in 3rd gear so i coasted the 1/2 mile home, stopped engine, restarted engine and the gearbox would work ok.
Today after covering 5 miles, whilst driving at 40mph coasting down a hill with foot off accelerator, i noticed a thumping through the drivetrain and after that the car was stuck in 3rd gear & i couldnt manualy shift gears. I stopped the car, removed ignition key, restarted engine & continuied the 3 mile journey home with gearbox working ok.
Car has covered 99,300 miles, has a fsh. I Changed the auto fluid and filter at 89,000 miles in nov 2007. I used the genuine MB auto transmission fluid.
Anyone Know what the probblem is?
Should i get the codes read with star diagnostics at my local independant gararge?
