AXE Rims
Nope, they will need 12mm - 15mm spacers to get them out to where the standard wheels are and bigger spacers 20 -25mm if you want them even more flush looking.
Thanks,
I don't mind spacers but not 25mm :ban:
So what ET should I be looking at to get that close to flush look??
Thanks,
8.5 ET30 9.5 ET31 are the factory fit for 19s
So you could go ET25 front and rear to pull them out just a little bit more... any more and you may have issues... you would need to ask around and don't forget the tyre shape/profile can affect the situation too.
Thanks for the info. :thumb:
I could also start off with ET30 , then add spacers to get the desired result.
