- Oct 4, 2019
- Location
- Guildford
- E250 Avantgarde Estate, Alfa GTV V6, Vespa, Ducati, many bicycles...
I think I need some egg sucking advise for sure, I’m getting more confused with this now!Grandmothers and eggs again...
Are your neighbours getting the same speeds and reliability as you? If you're all in the same (slow) boat, that's one story - that's down to BT
If it's only you that's got slower speed than expected, that's down to your router, your config, settings and devices.
Worth investigating. Try to compare speeds at roughly the same time. As you know performance varies between, say, mid-morning and early evening.
And you know that you should use 5ghz protocol on your iPhone and iPad for fastest speed, and 2.4ghz only if you're trying to cope with obstructions in the house?
And you have a clean line coming into your router? No silly redundant connections to sockets that you don't use any more?
Presumably you don't have signal repeaters on your network?
I think there are two issues, for sure there is a bt fault somewhere as it drops out completely and to last Tuesday its all worked fine.
But as I’ve tried to investigate I’ve also tried to improve the setup - but now I’m confused!
Basically the internet cable comes into the house through a BT Master socket 5c and plugs straight into a smart hub 2. There is also a TV attached to the hub via a bt tv box thing. I then have one Wi-Fi disc on the landing that feeds Wi-Fi upstairs. So far so good.
Then I have a tp-link powerline attached to the hub and that feeds another powerline in another room at the back of the house that the TV, another bt tv box thing and an audio pro speaker plugs into.
I then have another powerline in the stable at the end of the garden that has an Ethernet connection to another bt disc that gives me Wi-Fi for the shed/gym near the stable. I have power in both the stable and gym but the consumer unit is in the stable so that’s where I’ve put the powerline. I only seem to get 20Mb/s but it’s enough for Zwift and streaming movies when im on the rower.
Where I’m really confused is that I seem to have two networks that I can connect to and they seem to have different speeds. But the power lines must be on one only as to get internet in the shed I have to connect to a particular one.
The other thing is I can’t see which is 5Ghz or 2.4 as when I connect it just has the network name, no mention of the Ghz. The powerlines have both but again I can’t see how to select one or t’other!
I think my iphone and iPad automatically connect to whichever has the strongest signal? I can’t see how to change it.
Im sure there must be a simpler setup! Maybe I need to get someone round to take a look.
